how can we connect 6 transistor in parrallel???
what are the condition for parrallel operation of transistor???
Hu? That question makes sense only if somebody other ask.what are the condition for parrallel operation of transistor???
That's for bipolar transistors. But MOSFET transistors can have a significant difference in Vgs for the same current which makes balancing them even more difficult.Transistors do not play well together. If you connect the B.s together and the C.s together and the E.s together they will not share current.
If each transistor had its own emitter resistor, and the resistors had 0.3 volts (or more) across them at full load then they do some sharing. At 0.6V on the emitter resistors they play together fine. The transistors need to be at the same temperature. (on the same heat sink)
A dirty solution for this might be using same number of opamps to get each mosfet be part of their own feedback system.That's for bipolar transistors. But MOSFET transistors can have a significant difference in Vgs for the same current which makes balancing them even more difficult.
Here is a heavy duty treatise on that topic.That's for bipolar transistors. But MOSFET transistors can have a significant difference in Vgs for the same current which makes balancing them even more difficult.
