nuttaphong191
I am looking for a transistor that when its base or gate is not powered, it completes the circuit and when its base or gate is powered it breaks the circuit. Is posible to get this kind of transistor? Thanks
bananasiong said:PNP, on when the base grounded, off when the base approaching supplied voltage.
Gordz said:You could used an PNP that is biased on, and when you apply current to the base it will turn off. Or you could use the N.C. contacts of a relay.
ThermalRunaway said:You could also accomplish the same thing with a normal NPN. Brian
