Hi everybody, I've been on a 2 year hiatus from this site, been calling AAC home. But it's starting to feel a lot less like home, so here I am.
I thought it would be fitting that my first post upon return here is a topic that's banned on AAC: Transformerless power supplies.
I want to make a 12KVA CC/CV, AC/DC inverter power supply that I could use for conceivably any welding process including MIG, TIG, Stick, Plasma, etc.
I've been looking to commercial designs for inspiration and found a dearth of information. Those few welders that I was able to obtain data on, contained a transformer. Whether it be a clunky 60Hz xfmr on the input or a smaller HF xfmr after the inverter, they had a transformer. It might be totally possible that there are some transformerless welders out there, but I just didn't come across them.
My first question (there will surely be more, later on): Is the transformer absolutely necessary? Is there any reason I can't take a page from the polyphase motor VFD and just go with: rectifier > DC bus cap bank > DC bus choke > transistor output > (output reactor) > electrode?
I've drawn up a circuit in LTSpice for what I just described and it seems to work just fine. Using a 240V center-grounded input, I rectify one 120V leg to positive and the other 120V leg to negative, and pass the neutral straight through to the work clamp. AC output is accomplished by PWM pulsing POS(+) bus then NEG(-) bus to the electrode. This cuts down on the parts count; I only need 2 high power transistor modules to create a variable freq/current/voltage output, versus 4 (H-bridge) in the comparable transformer-based welder.
I realize that the electrode (when powered) would complete a circuit with anything conductive (and grounded) around it if touched. But this does not seem like a deal breaker, as that is normally true of typical welding conditions anyway (metal workpiece sits on grounded metal table, etc.).
Is there any other reason why this design would be "dangerous" (relative term, when playing with open arcs of "high" voltage, plasma, splattering pools of molten metal, and light bright enough to fry your retinas) or otherwise a bad idea? I assume there must be a good reason why the big name welders (those that I could confirm) continue to use transformers if it were so easy to dispense with them. So what is the reason?
