9 * 120 is probably on the edge of easy stuff: https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0CFUQFjAC&url=https://www.hammondpowersolutions.com/files/HPS_Catalog_Control_GenPurpose_Section1.pdf&ei=8S-OUv-3DdPnsATij4Fo&usg=AFQjCNGCGbfHc9poa3J6WWBSmzwThmq_Yg&bvm=bv.56988011,d.cWc&cad=rja
l
VA? VA? VA? VA? i.e. Volt-Amps
what exactly is a network box? why would it draw so much power?
9A at 208V = 2kVA
and that is more than standard 110VAC outlet can handle
9A at 208V = 2kVA
In any event, KV never said it was 9A @ 208V. That's what I'm complaining about.
20A * 0.08 (derating for continuous) * 120 = 1950 Watts
so, if he uses the 20 A outlet in the kitchen or bathroom and doesn't use the hair dryer or the microwave and the load really isn't continuous, it could work. Again if it is 9A at 208V
I have someone I work with who purchase a network box that runs on 208vac, he wanted to install it on a 110vac line.
I think it runs around 9-10amps so it wouldn't exceed a 15amp breaker. Anyone have suggestions?
Does he have any high power appliances in his apartment?
Rang, dryer, water heater. most run off 208 volts.
Cheak braker panel for 2 pole brakers.
Unplug high power applianc and plug in server rack.
Sorry I did not see that.That was what started the conversation, he wanted to hook into the stove outlet.
So whats the problum again?
