Timer Circuit. Need Help
justin312
Hey guys, I'm new to this forum but I need some help with a project.
Basically I have a pneumatic solenoid that's being run to a 12v DC power source and is triggered by a simple momentary push button switch. What I need is a timer or something where I can switch it on and after a 3-5 second delay the power goes to the solenoid which causes it to open. Any help would be appreciated and I can compensate the first person to send me plans for a prototype. I'm not very good with regular schematics so you'd have to dumb it down for me. (I'm a mechanical engineer by trade.)
Also the overall dimensions cannot be larger than 2.5 cubic inches.
Sounds like a job for a LM555 timer chip. What's the current requirement for the solenoid? Does the solenoid remain on until the 12V "system" power is removed? Is this an automotive application?
Ken
I am assuming he doesn't need it to stay on since he uses a momentary push button now. He will need to put a relay on the output to feed the solenoid probably.
I have a circuit I just soldered you can try.
In this schematic change R3 to change delay time and change R8 to change the on time of the relay on the output.
I don't know if this is what you are looking for but if it is you are more than welcome. if not, well we tried. :)
I would have a few questions:
1) Define momentary
a) Like a 10 millisecond push/edge trigger -or-
b) Hold button, and in 3-5 seconds it turns on.
Aside: I know you said momentary, but you also said switch it on. Your NOT looking for something that uses a on/off switch, but delays the power 3-5 seconds?
2) Define the current at 12V
4) clarify 2.5 cubic inch rule
a) If a relay was used, does the 2.5 cubic inches include it?
Aside: Solenoids don't "open" unless they break. They may "pull-in" or "activate". The solenoid could "open something" like the trunk.
Will be interesting to see his reply. I bet he has to hold it for the 3-5 seconds so everything gets going. If that is the case a simple timed one-shot would work.
