hi
My application is
12 inputs to the micro controller and 12 outputs drive the 12 relays
Each input is connected to the each relay using 89s51
Here 89s51 monitors the each input and switched on the corresponding relays by using opto couplers.
Now my problem is ,
I have to switch off the relay with in 15 – 30 seconds Irrespective of the input high.
Time should be seated by the user, variable time delay.
Please suggest required hard for this problem
Thanking you
Regards
My application is
Now my problem is ,
Thanking you
Regards
