Hey all
I have CC2510 evaluation module kit from Texas Instruments.
CC2510 is basically a 2.4GHz transceiver and has 8051 microcontroller built into it.
Datasheet - http://www.lierda.com/upload/product/down_path/070122/0697720001169436793.pdf
Debug and programming Interface - http://focus.tij.co.jp/jp/lit/ug/swra124/swra124.pdf
Also I would like you to know that a development kit is available to program the mcu. But its too expensive. So, I wanted to program the mcu without it.
Could I do that without the kit?
Also, I have ATMega-16 ICs from Atmel with their programmer. Could I use that IC(ATMega16) to program 8051 mcu of CC2510 evaluation module?
What softwares would I need? Could I write a program in C for 8051, compile it, translate the compiled exe to hex and then transfer the hex to 8051 using my ATMega16 ICs?? If this is possible, kindly guide me through the process like what libraries would be reqd to write a program for 8051, how is it transferred using ATMega16 etc.
Any other suggestions for doing this are welcome. Please help.
