Pastor Del
I've been tasked with testing some voltage suppressors. An engineer has given me the test setup & specs below, but all the components are failing. Should there be a load parallel to the suppressor in this test setup?
It doesn't get past step 3. At 1.5mA the voltmeter reads about 15.5V. The diode is a TPC18AHM3. Can you suggest a good way to verify its specs?
