The picture attached is my schematic.
I use the op-amp as a comparator to sense temperature and as the NTC thermistor's temperature increases its resistance decreases thus making the voltage at V(-) larger. When V(-) reaches a high enough temperature the op-amp will toggle "off" and turn the heater off.
I plan on changing the temperature level in which the comparator toggles "off" by changing the voltage at Vref via a digital to analog converter. I plan on using the outputs from the PID to create a boolean number into the D/A to make a voltage at Vref. As Vref changes the "toggle" point for the comparator will change.
Questions:
Will the PID control the D/A converter in the manner i have chosen?
Is that a wise approach in changing the desired temperature?
Do i need 21 different outputs from the PID to operate 3 seven segment displays?
Any help/feedback is appreciated. This is one of my first practical applications. I decided to try to use my engineering knowledge for at home purposes.
Thanks in advance.
Questions:
Thanks in advance.
