Hi folks,
I have no electronics experience but I'm hoping that someone can point me in the right direction here.
My problem is that I have a cabinet in which I need to maintain a reasonably constant temperature, between about 25 and 30 degrees Celsius. I've been searching the web for a ready made solution without any luck and then came up with the following crazy idea.
My plan is to use a peltier, sandwiched between two heat sinks. One of the heat sinks will be fitted into a casing so that a couple of fans can vent either warm or cold air into the cabinet whenever the internal temperature goes either side of the desired range. The other heat sink would be kept external with another fan attached to regulate the unit's temperature on the outside of the cabinet.
I've no idea whether this will actually do the job, but I don't have any better ideas at the moment, and where I'm really struggling right now is the design of the control circuit.
So, I've been looking into building a circuit using a thermistor, with a couple of potentiometers to adjust the min/max temperature limits, such that if the cabinet gets too warm the peltier will be powered with +/- set in one direction to cool the air flowing in, or if it drops too low then the polarity on the peltier power supply should be reversed so that the airflow is then being heated.
Looking on the web I found a page with these images that show a simple example of how to use a transistor to switch on an LED for when a light sensor is activated or alternatively when it is deactivated.
From these I've been trying to figure out how to modify this layout with the light sensor replaced by my thermistor but both options merged into a single circuit and, where the LED is, that would become the relevant hot or cold power supply feed for the peltier.
If anyone knows of a ready made unit I can use then I'd happily go for that. Otherwise I would very much appreciate someone (with a lot of patience) walking me through how to go about making some sort of progress on this project.
Thanks.
Thanks.
