soulraven
please help me with this code, trying to make a tachometer with pic16f887. only show me all the time 330.
Set CCP1 capture but in vain ....
where is wrong?
I put in main.c
ccp1_isr ();
turometru ();
where I wrong?
where is wrong?
I put in main.c
ccp1_isr ();
turometru ();
where I wrong?
#include "main.h"
#priority CCP1, TIMER1
#define BytePtr(var, offset) (char *)(&(char *)var + offset)
#byte PIR1 = 0xF9E
#bit TMR1IF = PIR1.0
int8 gc_timer1_extension = 0;
int8 gc_capture_flag = FALSE;
int32 g32_ccp_delta;
#int_timer1
void timer1_isr(void)
gc_timer1_extension++;
#int_ccp1
void ccp1_isr(void)
char timer_ext_copy;
int32 current_ccp;
static int32 old_ccp = 0;
gc_capture_flag = TRUE;
current_ccp = (int32)CCP_1;
// Get local copy of the timer ext.
timer_ext_copy = gc_timer1_extension;
if(TMR1IF)
if(*BytePtr(current_ccp, 1) < 2) // Was CCP captured after Timer1 wrapped?
timer_ext_copy++; // If so, inc the copy of the timer ext.
// Since we know a timer interrupt is pending, let's just
// handle it here and now. That saves a little load off
// the processor.
gc_timer1_extension++; // Increment the real timer extension
TMR1IF = 0; // Then clear the Timer1 interrupt
// Insert the timer extension into the proper place in the 32-bit
// CCP value.
// ie., Insert it into location "EE" as follows: 0x00EEnnnn
// (nnnn = the CCP).
*BytePtr(current_ccp, 2) = timer_ext_copy;
g32_ccp_delta = (current_ccp > old_ccp) ? current_ccp - old_ccp : current_ccp + (0x1000000 - old_ccp);
// Save the current ccp value for next time.
old_ccp = current_ccp;
void turometru()
int16 frecventa;
int16 frequency;
int32 current_ccp_delta;
set_timer1(0);
setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
setup_ccp1(CCP_CAPTURE_RE);
// Enable interrupts.
clear_interrupt(INT_TIMER1);
enable_interrupts(INT_TIMER1);
clear_interrupt(INT_CCP1);
enable_interrupts(INT_CCP1);
enable_interrupts(GLOBAL);
//while(1)
disable_interrupts(GLOBAL);
current_ccp_delta = g32_ccp_delta;;
if(gc_capture_flag == TRUE)
frequency = (int16)((5000000L + (current_ccp_delta >> 1)) / current_ccp_delta);
frecventa = (frequency * 60)/2;
lcd_gotoxy(5,1);
printf(lcd_putc,"%lu\n", frecventa);
printf("%lu\n\r", frecventa);
// printf(lcd_putc,"%lu Hz, delta = %lx \n\r", frequency, current_ccp_delta);
else
lcd_gotoxy(5,1);
printf(lcd_putc,"0 \n");
printf("0 \r");
delay_ms(100);
