Swordfish Example
gramo
I was just writing a conversion for some of my 16F projects to Swordfish, and realized that this little program covers many aspects of Swordfish all in one. It’s a simple 7 segment multiplexing program for the following circuit;
And heres the code;
[B]Device [/B]= 18F452
[B]Clock [/B]= 20
#[B]option [/B]_Segment_Port = PORTC                      // Define the Keypad PORT
#[B]option [/B]_Segment_TRIS = GetTRIS(_Segment_Port)     // Nice way to automatically get the TRIS
                                                   //  automatically from a selected port
[B]Include [/B]"ISRTimer.bas"
[B]Include [/B]"utils.bas"
[B]Dim [/B]Segment_1_TRIS As TRISD.1,                     // User must define what pins control
    Segment_2_TRIS As TRISD.0,                     //  each segment
    Segment_1 As PORTD.1,
    Segment_2 As PORTD.0
[B]Dim [/B]Number As Byte,                                // Program variables that require no
    Segment_Data As _Segment_Port,                 //  user settings
    Segment_TRIS As _Segment_TRIS,
    Segment_1_Data As Byte,
    Segment_2_Data As Byte
[B]Const[/B]
    Timer1 = 0,
    Timer2 = 1
// Update_Segments event, mutiplex the segment data...
[B]Sub [/B]Update_Segments()
    If Segment_1 = 1 Then
        Segment_1 = 0
        Segment_Data = Segment_2_Data
        Segment_2 = 1
    Else
        Segment_2 = 0
        Segment_Data = Segment_1_Data
        Segment_1 = 1
    EndIf
[B]End Sub[/B]
[B]Function [/B]Segment_Encode(Segment_Byte As Byte) As Byte  // Convert a byte into segment information
    Select Segment_Byte
    	    Case 0
    	   	Result = %00111111
    	    Case 1
    	   	Result = %00000110
    	    Case 2
    		Result = %01011011
    	    Case 3
    	   	Result = %01001111
    	    Case 4
    	   	Result = %01100110
    	    Case 5
    	   	Result = %01101101
    	    Case 6
       		Result = %01111100
    	    Case 7
     		Result = %00000111
    	    Case 8
    		Result = %01111111
    	    Case 9
     		Result = %01100111
    	EndSelect
[B]End Function[/B]
[B]Sub [/B]EncodeSegmentData()                          // Encodes segment data
    Segment_1_Data = Digit(Number,1)             // Extract the first digit & convert it
    Segment_1_Data = Segment_Encode(Segment_1_Data)
    Segment_2_Data = Digit(Number,2)             // Extract the second digit & convert it
    Segment_2_Data = Segment_Encode(Segment_2_Data)
[B]End Sub[/B]
// Increment_Number event will increment the register Number
[B]Sub [/B]Increment_Number()
    Inc(Number)
    If Number = 100 Then
        Number = 0
    EndIf
    EncodeSegmentData
[B]End Sub[/B]
[B]Timer[/B].[B]Initialize[/B](2)                              // initialize the timer module...
// initialise each timer
[B]Timer.Items[/B](Timer1).Interval = 5                 // 5ms
[B]Timer.Items([/B]Timer1).OnTimer = @Update_Segments   // timer1 event handler
[B]Timer.Items[/B](Timer2).Interval = 500               // 500ms
[B]Timer.Items[/B](Timer2).OnTimer = @Increment_Number  // timer2 event handler
Number = 0                                       // Initialize variables
EncodeSegmentData
Segment_TRIS = %00000000                         // Make the segment data lines outputs
[B]Low[/B](Segment_1_TRIS)
[B]Low[/B](Segment_2_TRIS)
[B]Timer.Items[/B](Timer1).Enabled = True               // enable the timers...
[B]Timer.Items[/B](Timer2).Enabled = True
[B]Timer.Start[/B]                                      // start processing all timers...
// main program loop...
[B]While True[/B]
[B]Wend[/B]
Some of the features are;
* A quick sample of the comprehensive 'on compile' commands (#option in this case)
* Swordfish's ISRTimer Library
* Functions
* Sub Procedures
Notice that the main program loop is simply
While True
Wend
The ISRTimer library creates the required interrupt settings to perform the multiplexing and number incrementing 'on the fly'
