If the input is the ac mains supply, what you need is a transformer and a rectifier, not a switching power supply.
A 10Kva transformer is going to be quite a large and expensive beast.
The Desired output is DC 48Volts 200Amps and Input is AC 230V at 50 Hz
Hi Ron,
Ok the Power Supply is required to convert the AC to DC which is connected to a DC Motor to drive the Load. The Motor requirement is DC48Volts at 200A. This is running non-stop. So the required AC input has to be low in order to save Power.
I agree but maybe it's for a safety reason?For what building a 48 volt 200 amp power supply will cost or just purchasing one you probably would be better off just buying a replacement motor that runs on line voltage.
Perhaps he's not allowed to use a lethal voltage so he's using the highest non-lethal voltage he possibly can?
