I would like to build a HV low current source that can be connected across a large area plate capacitor and switched at very low frequency (1-10Hz). The purpose is experimentation with dielectric films.
The first thing that came to mind was a domestic negative ion generator. Some have an acceleration grid that is connected to “ground”, thus providing access to a complete circuit. Within the frequency range mentioned above, I would expect the capacitor to draw negligible current.
Is there any practical way to switch the ion generator’s output? In other words, between the negatively charged pins and ground with the cap wired in series across them. As I understand, the nominal voltage is around 2-5KV at whatever small current the HV bridge can supply.
With regard to cycling the cap, I am thinking the capacitance may be low enough so it does not retain charge. However, if this is not the case, would be the best way to provide a discharge path that is does not overload the ion generator and will tolerate the voltage applied?
