twinturbotom
I still have more testing and research to do but I'm turning to the experts for some direction; I appreciate any feedback...
I would like an irrigation pump to turn on based on the amount of water saturation inside of a garden bed. Been a fun project to build everything up and now I need some advice....
high level view: Solar panel recharges a battery which runs a pump. I would like to run a low voltage line (1-3 Volts) through my garden bed. The amount of water in the bed will change the resistance through the line. I need to do some testing here to figure out what the max and min resistances / currents would be based on water in my soil and then come up with the threshold value for pump on/off...
for arguments sake lets just say it's that simple... run a wire through the bed and the resistance goes up or down. I'm having trouble figuring out the best way to capture that information and use it to switch on the pump.
I'm pretty sure the resistance will go DOWN as the water content goes up. Therefore the pump should turn on when the resistance of the "sensing" circuit goes above a critical value and turns off when the resistance is below it. Not sure if it makes more sense to talk in terms of the circuits resistance or current here... Key is the pump should normally be OFF.
I imagine there being two or three circuits... the low voltage sensing circuit, pump circuit and some switching component or circuit that turns the pump on or off. I'm really unclear as to what that switching circuit or component is to work the way i want. Seems like some Relay? Anyway... any direction on the switching or relaying of a signal so that a pump goes on when the resistance through a sensing circuit goes up / current goes down would be helpful.
Thanks!
Thanks!
