credfern8807
I'm wanting to run a car stereo from a computer power supply but also a battery when an outlet is not available and be able to select which one I want to use. I have a couple of ideas so far... 1) simply use a spdt switch rated above 10A (fuse on stereo) to switch between batt/psu/off. 2) use a spst switch for a simply on/off and a spdt relay to have the power supply be the normal power for the stereo and the battery power the system when the psu is off. Also, I am wanting to run a fan in the box to cool the stereo and was wondering if I could somehow wire this to the same switch / switch-relay system or if it would be better to use a separate switch / switch-relay for the fan control. Which of these configurations is best and/or are there any better ideas for this system?
