Surface mount tools
gray5596
Does anyone recommend a tool for holding surface mount components? I recently had to replace a surface mount transistor, SOT23 and my hand held suction tool that I use for ICs wasn't able to hang onto this tiny device. (There has to be something better than a toothpick and superglue)
alec_t
Most Helpful Member
Could you make an adapter for the tool nozzle? Can you post a pic of the tool?
Mosaic
I apply gel rosin flux or simply pure petroleum jelly to the part before placing. I place & nudge with tweezers mainly, not the vacuum tools. Hot air if used at an angle can blow a part off the pads, also if the air flow rate is large the same can happen. Occasionally when replacing parts in an assembly with a steep gradient you will have to hold the part in place while using the hot air or tinned iron tip.
Mixing down old solder paste with rosin gel can improve the application process and make the pads more tacky.
gray5596
Ian, yes, I was using an iron instead of a heatgun. I will try the solder paste next time and plan to shop around for a heatgun. Thanks for all the replies.
EE World Online Articles
Loading
