hi guys,
I have to drive a mechanical relay from an edge Triggered D-flip flop. output voltage from the flip flop at max when using IC 4013 is 17.27 volts at 40.6 mA. My relay coil rating is 24 volts, although i can drive it using 16 volts because minimum driving voltage is 70% of the max rated coil voltage. i have tried transistor 2N5296 but i am not able to bias it properly i guess. so basically i'm stuck. Any suggestions. thanks
