I'm working on a project that includes a microcontroller, an Atmel dataflash memory chip and an audio amplifier. Because the Atmel dataflash chips are only designed for 3.3V, I'm running the whole circuit at that voltage level rather than dealing with the added complexity of running with both 5V and 3.3V. As an added benefit, the power consumption of the circuit is lower than I expected.
The whole project will have to run on battery power. At this point, due to size constraints, convenience and cost, I've decided to use a 9V battery as the power source. The toy is designed to be used in short bursts of only a few minutes at a time. During active use it will consume 50 mA at most. It will automatically go to sleep when not in use and should consume no more than about 10 µA when sleeping. Thus, a typical 9V alkaline battery (with on the order of 500 mAH capacity) should last a good long time.
I've been powering my prototypes from a 3.3V power supply up until now, but it's time to finalize the circuit, so I'm looking for a simple, efficient and low cost way to convert from 9V (really 9V-5V over the life of the battery) down to ~3.3V (and 3V would be just fine, too).
The only chip I've found that meets the criteria (simple, efficient, low cost and consumes hardly any power in standby mode) is the ST763A. I'm ordering a few of these to play with. That said, I've searched the web a bit and haven't found anyone else talking about this chip. Does anyone have experience with it or have a recommendation for another option?
