Static Electricity light LED
ibwev
I am trying to help my 4th grade son with his science project. Would rubbing the PVC against the Rabbit Fur using the attached diagram allow the LED to light? If so, please help with the following questions:
1) What size diode would be required to prevent the capacitor from discharging between the PVC and Rabbit Fur?
2) According to an article I read, one can expect up to 30 kV of static electricity when rubbing the PVC with the Rabbit Fur. Would a 50 kV rated capacitor with capacitance of 400 pF suffice ( such as, UHV-253A )?
3) Would a resistor between the capacitor and the voltage regulator suffice for reducing the voltage to 5V?
  • science fair .pdf
Hate to bring bad news, but this will not work. First, there is only picoA of current created by rubbing the fur; you need milliA to light a LED. Second, a voltage regulator chip has a maximum input voltage spec, typically about 30V. What is it going to do with a few thousand Volts?
You might have to go old school with a neon bulb.
It won't be bright but you should see it glow in the right conditions.
