stack overflow problem in pic 16f628a
rakhiwilliams
we are doing project using pic 16f628a.we completed coding (in assembly)
we are debugging our code using MPLAB simulator.here we are getting stackoverflow error at table(we are using for 7 seven segment display).
how to rectify this problem.we dont know the reason why we are getting this type of error.please anybody explain this.
thank you,
pic problem
sir,
could you tell me the reasons when will we get this stackoverflow problem.how can we overcome this problem generally.
Stack overflow means you have used all the available stack locations. The pic only has 8 (2 on some) stack locations. This is normally enough. Are you doing a call without a return by any chance?
I.E.
Loop		Call	Subroutine
		goto	Loop
Subroutine	;some code
		goto	Loop
The above would cause a stack overflow because every time the call is made a return address is placed on the stack.
As Pommie says, or if you have multiple call's without returning them.
e.g. one routine calls another. Within this called routine, you have yet another call, and so on and so forth... If you have these repeats for more than 8 levels, you will hit the Stack Overflow error
I have had to use is some cases the dreaded GOTO, to reduce the number of calls. The problem with a GOTO routine is that you would almost always have to return to the original caller with a GOTO command back to the requesting routine, which makes the code not really re-usable as opposed to CALL routines.
As Nigel said, post the code, some of the Guru's could possibly help you debug, else you will have to run the MPLAB simulation yourself, and keep note of the STACK Register.
Improperly constructed interrupt service routines can do the same thing. It is a 99.999% chance that the problem is in your code. Review it carefully, simulate it if necessary, pay someone to fix it if all else fails.
sir,
Though there is a stack overflow error, we are getting output correctly .
we dont know whether there will be any problem in future.what will happen to registers when stack overflow occurs.
To ask that question, I am guessing that the overflow is caused by using call instead of goto or goto instead of return (the alternative is that you have nested calls deeper than 8 - unlikely - unless your code is very complex or your imitating a windoze programmer :D :D ). Post your code and we may be able to fix it or have a guess what will happen in the real world.
You need to call the table lookup function. Do not use goto.
For example:
; # is in W for lookup table
[B]call[/B] getcode
getcode
	addwf PCL,F
codes
	retlw Key1
	retlw Key6
	retlw Key5
	retlw Key9
Do NOT do this:
goto getcode
Pommie said:
Your example would cause a stackunderflow error.
The code was just an example, not something you could compile and run. To clarify:
; # is in W for lookup table and is between 0 and 3
call getcode
[B]goto somewhere[/B]
getcode
	addwf PCL,F
codes
	retlw Key1
	retlw Key6
	retlw Key5
	retlw Key9
EDIT: Ok Mike. I see what you mean now. The goto getcode would cause an underflow not an overflow. :eek:
hi
i also get error message stack overflow. the problem is, when i simulated this program using MPLAB IDE, it runs perfectly for the first cycle but it stopped running when it reaches the middle of the program for 2nd cycle. i tried to put return for every subroutine i sued..but it still doesn't work
it always stopped at subroutine WaitxTE which i pasted below. can you check this subroutine for me please?
WaitxTE
movwf Count2 ; [1]
waitxlp
movlw D'30' ; [1]
movwf Count ; [1]
;wait400lp
;nop ; [1]
;nop ; [1]
;decfsz Count,F ; [1]
; goto wait400lp ; [2]
; 79 x 5 = 395us
decfsz Count2,F ; [1]
goto waitxlp ; [2]
retlw 0 ; [2]
did i miss something??
please help me..i've been working for this program quite a long time now
sorry..the code is below
;nur azrin hilmi
;gdp 17-telemetry
;use external clock
 	list        P=pic12f675        ; list directive to define processor
 	#include    <p12f675.inc>  ; processor specific variable definitions
;************************************************************8
; declaring all the registers
	cblock 0x20
	status_temp
	w_temp
	CSR0                      ; TX buffer shift register
	CSR1
;	CSR2
;	CSR3
;	CSR4
;	CSR5
;	CSR6
;	CSR7
;	CSR8
	Count
	Count2
	BitCount
	counter
	TimeHi
	TimeLo
	count
	address
	FuncBits
	input
	store
	nobit
	rotateright
	endc
;************setting the configuration bit******************8
; Data Memory Code Protection bit:  disabled
; _CPD_ON = Enabled
; _CPD_OFF = Disabled
; Program Memory Code protection: disabled
; _CP_ON = Enabled
; _CP_OFF = : Disabled
; Brown-out Detection Enable bit: disabled
; _BODEN_ON = Enabled
; _BODEN_OFF = Disabled
; GP3/MCLR pin function select:  mclr_on
; _MCLRE_ON = GP3/MCLR pin function is /MCLR
; _MCLRE_OFF = GP3/MCLR pin function is digital I/O,
;              /MCLR internally tied to Vdd
; Power-up Timer Enable bit: disable
; _PWRTE_ON = Enabled
; _PWRTE_OFF = Disabled
; Watchdog Timer Enable bit: disable
; _WDT_ON = Enabled
; _WDT_OFF = Disabled
; Oscillator Selction bits: _INTRC_OSC_NOCLKOUT
; _EXTRC_OSC_NOCLKOUT = CLKOUT function on GP4 pin, RC on GP5 pin.
; _EXTRC_OSC_CLKOUT = I/O function on GP4 pin, RC on GP5 pin.
; _INTRC_OSC_CLKOUT =  Internal oscillator, CLKOUT function on GP4 pin,
;                      I/O function on GP5 pin.
; _INTRC_OSC_NOCLKOUT = Internal oscillator, I/O function on GP4 and GP5 pins.
; _EC_OSC = I/O function on GP4 pin, CLKIN on GP5 pin.
; _HS_OSC = High speed crystal/resonator on GP4 and GP5 pins.
; _XT_OSC = Crystal/resonator on GP4 and GP5 pins.
; _LP_OSC = Low power crystal on GP4 and GP5 pins.
    __CONFIG    _CPD_OFF & _CP_OFF & _BODEN_OFF & _MCLRE_ON & _PWRTE_OFF & _WDT_OFF & _INTRC_OSC_NOCLKOUT
;**************define variables*********************************
	#define	sensor	GPIO, 1
	#define txd     GPIO, 2             ; (Output) Transmit Data
	#define pb3     GPIO, 3             ; (Input Only) Push button switch GP3
	#define pb4     GPIO, 4             ; (Input) Push button switch GP4
	#define rfena   GPIO, 5             ; (Output) RF Enable
 	; GPIO Pins =    xx543210
;	#define gptris b'00011011'
	#define TGUARD  d'18'
;	#define rotateright d'1'
	#define	countermax d'8'
	org  0x00
	goto initialize
	org  0x004
	movwf	w_temp
	swapf	STATUS,W
	bcf		STATUS, 5		;select bank 0
	movwf	status_temp		;save status register
;	interrupt service routine (ISR)
;   interrupt on change on pin of gpio
	movfw	GPIO
	bcf		INTCON,0
	swapf	status_temp,w	;set bank into original state
	movwf	STATUS
	swapf	w_temp,F
	swapf	w_temp,W
	retfie
;subroutine data_eeprom read
data_eeprom_read
	bsf  	STATUS,5
	movwf	EEADR
	bsf		EECON1,0
	movfw   EEDATA
	bcf     STATUS,5
data_eeprom_write
	bsf		STATUS,5
	bsf		EECON1,2
	bcf		INTCON,7
	movlw	0x55
	movwf	EECON2
	movlw	0xAA
	movwf	EECON2
	bsf		EECON1,1
	bsf		INTCON,7
	bcf		EECON1,2
	bcf     STATUS,5
	return
WaitxTE
        movwf   Count2      ; [1]
waitxlp
        movlw   D'30'       ; [1]
        movwf   Count       ; [1]
;wait400lp
      ;nop                 ; [1]
      ;nop                 ; [1]
;                         79 x 5 = 395us
     goto    waitxlp    ; [2]
        retlw   0           ; [2]
;                       total 2 (call) + W x (395 + 5) + 2 (return)
;                       w = 1 -> 406us @4MHz
;                       w = 2 -> 806us @4MHz
;initialize pic
initialize
;clearing all ports
	CLRF	nobit
	clrf	input
	clrf	store
	clrf	rotateright
	clrf	Count
	clrf	Count2
;disable global interrupts during initialization
	bcf     INTCON,7
;calibrating the internal oscillator
;	bsf     STATUS,5		;select bank 1
	call	0x3FF
	movwf	OSCCAL
;	bcf		STATUS,5
;turn off the comparator
	bsf		STATUS,5
	clrf 	ANSEL			; clear ansel register
	bcf		STATUS,5
	clrf 	GPIO			; initialize General Purpose Input Output to 0
;setting gpio register to the cosrresponding io pin
	bsf 	STATUS,5
	bcf		TRISIO,0
	bsf		TRISIO,1
	bsf		TRISIO,4
	bcf		TRISIO,2
	bCf		TRISIO,5
	bcf     STATUS,5		;select bank 0
;set bit 0:2 at register cmcon	;setting gp2 as digital output |offkan comparator
	bsf		STATUS,5
	bsf		CMCON,0
	bsf		CMCON,1
	bsf		CMCON,2
	BCF		STATUS,5
; VRCON	register ; CVref circuit powered down,no Idd drain
	bsf		STATUS,5
	bcf		VRCON, 7
	bcf		STATUS,5
;****timer1 module gate control**********************************
; disabling timer1
	bsf		STATUS, 5		; select Bank 1
	movlw   b'01000100'		; disable TIMER1
	movwf	T1CON		;
	bcf		STATUS, 5		; select Bank 0
;weak pull-up register (wpu)
;each pull-up is automatically turned off when the pin is configured as an output
	bsf     STATUS,5
	movlw	b'00010000'
	movwf	WPU
	bcf     STATUS,5
;***************set pin for config_address regsiter
;OPTION Register
;   OPTION_REG contains control bits to configure:
;   Weak pull-ups on GPIO (see also WPU Register above)
;   External GP2/INT interrupt
;   TMR0
;   TMR0/WDT prescaler
        bsf     STATUS,5	         	; ---- Select Bank 1 -----
        bcf     OPTION_REG, NOT_GPPU  	; GPIO pull-ups: enabled
        bsf     OPTION_REG, INTEDG  	; Interrupt Edge: on rising edge of GP2/INT pin
        bcf     OPTION_REG, T0CS    	; TMR0 Clock Source: internal instruction cycle (CLKOUT)
        bcf     OPTION_REG, T0SE    	; TMR0 Source Edge: increment low-to-high transition on GP2/T0CKI pin
        bcf     OPTION_REG, 3     		; Prescaler Assignment: assigned to TIMER0
        ; TMR0 Prescaler Rate: 1:2
        bcf     OPTION_REG, 2     		; Prescaler Rate Select bit 2
        bcf     OPTION_REG, 1     		; Prescaler Rate Select bit 1
        bcf     OPTION_REG, 0     		; Prescaler Rate Select bit 0
        bcf    STATUS, 5         		; ---- Select Bank 0 -----
;interrupt on-change register
	bsf     STATUS,5
	movlw  	b'00011010'		;enable global interrupts in order for the individual pin to be configured(kalo switch
	movwf	IOC
	movlw	b'00000000'		;peripheral interrupt register; disable
	movwf 	PIE1
	bcf    STATUS,5
	movlw	b'00001000'		;enable interrupt control register
	movwf	INTCON
;MAIN PROGRAM
;*****************************************************************8
MAIN
        bsf     INTCON,7  ; enable global interrupts
	;	bsf		rfena     ; enable	transmitter
		goto    BITCHECK
;CHECK INPUT
	movlw	d'1'
	movwf	rotateright
BITCHECK
	incf	nobit,f
	movfw	GPIO
	movwf	input
	movlw	0x00
	xorwf	input,f
	btfsc	nobit,0
	goto	bit0
    goto	bit1
bit0
	rrf		input,w
	movwf	store
	goto	BITCHECK
bit1
	movlw	0x00
	xorwf	input,w
	xorwf	store,f
checkbit
	btfsc	nobit,3
	goto	TRANSMIT
	incf	nobit,f
	movfw	nobit
	movwf	rotateright
	movfw	GPIO
	movwf	input
	movlw	0x00
	xorwf	input,f
	decf	rotateright
	decf	rotateright
rotate
	rlf		input,w
	xorwf	store,f
	decfsz  rotateright,f
	goto	rotate
	goto	checkbit
	goto	TRANSMIT
TRANSMIT
		bsf		GPIO,5
; send preamble (50% duty cycle)
Preamble					;send 16 bit
      movlw   d'5'
      movwf   BitCount          ; init number of preamble bits
PreL
        bsf     txd             ; ON
        movlw	1
		call    WaitxTE           ; delay
        bcf     txd             ; OFF
       	movlw	1
        decfsz  BitCount,F      ; loop
        goto    PreL
; sync pause
TXloop
       movlw d'10'
	   call    WaitxTE         ; Theader = 10 x Te
; send 72 bit pattern
        movlw   CSR1            ; lsb first
        movwf   FSR
TXNextByte
      movlw   D'8'
      movwf   BitCount
TXNextBit
        rrf     INDF,W           ; 8 bit rotate | rotate right f through carry
        rrf     INDF,F           ; Carry contain lsb
        BC      ONE				 ; branch on carry | goto ONE if bit is set
ZERO    					;wave pattern if the bit is zero
        movlw   2               ;
	    movwf   TimeHi          ;   +---+---+   +--
        movlw   1               ;   |       |   |
   		movwf   TimeLo          ;---+       +---+
        goto    Trasm_BIT       ;   |  2Te   Te |
ONE							;wave pattern if the bit is one
        movlw   1              	;
        movwf   TimeHi          ;   +---+       +--
        movlw   2               ;   |   |       |
        movwf   TimeLo          ;---+   +---+---+
                                ;   | Te   2Te  |
Trasm_BIT
        bsf     txd             ; ON
        movf    TimeHi,W
        call    WaitxTE
        bcf     txd             ; OFF
        movf    TimeLo,W
        call    WaitxTE
       	decfsz  BitCount,F
        goto    TXNextBit       ; loop on bits
; guard time
        movlw   TGUARD
        call    WaitxTE
       org     0x3ff
       retlw    0x80
        end                         ; end of program directive
i tried to post the full code but it doesnot work..it lost everytime i refresh the page
can i have your email..so that i can email you the code?
; guard time
        movlw   TGUARD
        call    WaitxTE
       org     0x3ff
       retlw    0x80
your code not ending,after call WaitxTE it continue running to the end of memory then repeat from begining, here it found "retlw 0x80" then return to nowhere
solution : use goto
 ; guard time
       movlw   TGUARD
       call WaitxTE
    goto begin_of_loop
       org     0x3ff
       retlw    0x80
