WTP Pepper
Active Member
I am after the the following but cannot find anything that meets my spec so I would appreciate some input from the forum.
Single chip solution.
1Hz square wave oscillator
Current < 50uA
Temp compensated to less than 5ppm over 0-40deg C
3v operating voltage.
Non I2C control.
No RTC solutions as they draw current when actively being interrogated.
As small as possible.
I don't mind if 1Hz is derived from a higher frequency, but it still must be small and draw very little current and be temp compensated.
I want to wake a sleeping CPU every second to update a UNIX timed counter clock and do a few checks before going back to sleep. The CPU runs on an internal 10KHz clock during this "wakeup" period and draws microamps. I want the clock to not draw too much of this current budget. Otherwise the CPU is sleeping and drawing a few of microamps.
TIA
Current < 50uA
Non I2C control.
TIA
