april
I have a circuit running on 24V which is supplied from a split rail power supply. -12V one side and +12V the other . Zero in between but not used here. This is one of those kit power supplies popular 20 odd years ago in magazines.
It runs my project which is a LED spreader light with a constant current source attached inside and fed 24V from the above .
The light is switched on and off by an ATTiny85 chip through two transistors which turn on a MOSFet.
and the ATTiny is powered by the same supply dropped down with a LM78L05 voltage regulator. A PIR movement sensor takes 5V also and tells the chip when movement is detected and an LDR tells the chip when it is dark .
So there it is and it all works particularly well, however...
When I try to connect it to a 24 V battery bank it wont work , the symptoms it displays are strange and changeable
Can anyone suggest anything obvious that might be going on ?
