Hi thanks for the quick reply.
The maximum depth will be approx 25 meters and will always be in fresh water.
We want to be able to identify the following different types of bottom
-mud& sand
-gravel/hard bottom
-weed
A 200KHz transducer pulse power of approx 80Watts will give good depth results down to 80mtrs, this will allow a pulse rate of 10ppsec
For a depth of 25mtr, 40Watts at 20pps, with a pulse width of 100uS to 200uSec.
I know that the 'Roxann' system can differentiate between mud, sand and shingle bottoms,, [weed I have never tried.]
Read the pdf in that link and you will see that the 'echo' envelope does contain some information about the bottom conditions.
I would suggest you first build the 200KHz transceiver and then find 'bottoms' with the required parameters.
The receiver should have TGC [timed gain control] settings, to allow for the attenuation of the signal levels at increasing depths.
If you attach a scope or better still a echo sounder paper trace you will have a record of the different bottoms.
EDIT:
I should ask you what is the beam width of your transducer...?
8 degree is more for depth working and 2.5degree will give a sharper echo response [which you want]
