hi
i havnt actualy tried the following programs yet as ive been reading through the code to see how i will need to alter it for my needs if i decide to use i2c instead of spi after reading through the code there are some aspects that i dont understand why its done that way etc. before i show the code and explain my questions i will give a rundown of what i am doing
ok hi this is of course for my robot project and i know that if i realy try then i could come up with a way of just using one pic to do all i will need BUT i dont want to do it that way and i will get more points by doing it a different way so the plan is a master pic wich at present is a 18f4685 wich is boss and takes care of the LCD etc then i have planned to use a 18f1330 for motor control (it has good pwm modual) and line sensors and bump sensor (micro switchs) then i plan to use some along the lines of a 18fxxK22 for the metal detecting (circuit still not fully decided) and probaly for the laser addon. theese chips will need to talk to each other and at first i was going to use SPI (i have used it a couple of times) but i am now thinking of going I2C as i dont need realy realy fast speed and i like the 2line coms.also my BOT will have the abillity to have other addon boards plugged into the main board so the bot can do diffferent jobs. please dont tell me its all pointless to do it this way because i have a good reason for this approach the bot is a competition that some must do parts like the line following race and metal detecting and telling gold coloured metal from silver coloured metal and there is a part of the comp that will test how long the bot will run for on one charge/set of bats.
this is all must do parts
then there is other part of comp that your bot gets judged by my school pupils on things like looks and wow factor and abillity to do cool stuff (i goto a technology school) Okehampton. so my plan is to have a busy main board with plenty of bits and led indicators etc so it looks complicated and cool and rather than have all the stuff on one board i plan to have my addon boards laid out next to the bot for the judging with description and write up of each board again i am sure this will get extra points also my bot is the only bot in the competion that is completly home made all the others are now ones that were got from shops or ebay and just altered so the teacher judges will give me megga more points for that so i have decided to have a go at a I2C bus ive read loads of threads on here and seems no one is that keen on I2C slave pics i noticed that a couple of years ago mr nigle didnt think pic slaves were a good idea and I2C bus was best if you had I2C chips. so i am aware of the bad bits that mr nigle pointed out but i still think I2C would be cool
i found some Master and slave I2C code examples from microchip and they are the programs i have been studying but i am a bit unsure of the way they have made it work i am not going to use the code as is but before i mess with it i wanted to ask some questions so here is there code BTW there code is well comented
I2C MASTER PIC CODE
I2C SLAVE
ok the questions
on the slave code look at this part
ok i see it sets its address at 0xA2 thats fine
it then reads from master and sends some data itself but nowhere can i see where it actualy checks to see if the information is for itself or another slave
surely somewhere after the first read it should chk to see if the address the master sends is for itself???
also why does it read the sent address at the very end instead of the beginning ????
then on the master side
why does it send data then idle the restart???
i have other questions but that will do for now
thank you
forgot to add that on main board is also a 18fxxk22 for doing nothing but flash leds under bot for diff reason and just doing fancy stuff to look cool no real purpose stuff
I2C MASTER PIC CODE
#define USE_OR_MASKS
#include <p18cxxx.h>
#include "i2c.h"
//-------------------------------Configuration setting ----------------------------------------------
* Oscillator is configured as HS
* Fail safe monitor is enabled
* watch dog timer is disabled
* Extended instruction mode is disabled
* oscillator switch over is enabled
#if defined(__18F4685) //If the selected device if PIC18F4685, then apply below settings else user will have to set
#pragma config OSC=HS, FCMEN=ON, WDT=OFF, IESO=ON, XINST=OFF, LVP=OFF
#endif
unsigned char I2C_Send[21] = "MICROCHIP:I2C_MASTER" ;
unsigned char I2C_Recv[21];
//************ I2C MASTER ****************************
void main(void)
unsigned char sync_mode=0, slew=0, add1,w,data,status,length;
for(w=0;w<20;w++)
I2C_Recv[w]=0;
add1=0xA2; //address of the device (slave) under communication
CloseI2C(); //close i2c if was operating earlier
//------------------------INITIALISE THE I2C MODULE FOR MASTER MODE WITH 100KHz ---------------------------
sync_mode = MASTER;
slew = SLEW_OFF;
OpenI2C(sync_mode,slew);
SSPADD=0x0A; //400kHz Baud clock(9) @8MHz
//check for bus idle condition in multi master communication
IdleI2C();
//--------------------START I2C---------------
StartI2C();
//**************write the address of the device for communication************
data = SSPBUF; //read any previous stored content in buffer to clear buffer full status
do
status = WriteI2C( add1 | 0x00 ); //write the address of slave
if(status == -1) //check if bus collision happened
data = SSPBUF; //upon bus collision detection clear the buffer,
SSPCON1bits.WCOL=0; // clear the bus collision status bit
while(status!=0); //write untill successful communication
//R/W BIT IS '0' FOR FURTHER WRITE TO SLAVE
//***********WRITE THE THE DATA TO BE SENT FOR SLAVE****************
while(putsI2C(I2C_Send)!=0); //write string of data to be transmitted to slave
//-------------TERMINATE COMMUNICATION FROM MASTER SIDE---------------
IdleI2C();
//-----------------RESTART I2C COMMUNICATION---------------------------------------
RestartI2C();
IdleI2C();
//R/W BIT IS '1' FOR READ FROM SLAVE
add1 = 0xA2;
do
status = WriteI2C( add1 | 0x01 ); //write the address of slave
//******************* Recieve data from slave ******************************
while( getsI2C(I2C_Recv,20) ); //recieve data string of lenght 20 from slave
I2C_Recv[20] = '\0' ;
NotAckI2C(); //send the end of transmission signal through nack
while( SSPCON2bits.ACKEN!=0); //wait till ack sequence is complete
//********************* close I2C *****************************************
CloseI2C(); //close I2C module
while(1); //End of program
I2C SLAVE
#endif
unsigned char I2C_Send[21] = "MICROCHIP:I2C_SLAVE" ;
//************ I2C SLAVE ****************************************
void main(void)
unsigned char sync_mode=0, slew=0, add1,status,temp,w,length=0;
for(w=0;w<20;w++)
I2C_Recv[w]=0;
sync_mode = SLAVE_7;
slew = SLEW_OFF;
SSPADD = 0xA2; //initialze slave address
//********************* Read the address sent by master from buffer **************
while(DataRdyI2C()==0); //WAIT UNTILL THE DATA IS TRANSMITTED FROM master
temp = ReadI2C();
//********************* Data reception from master by slave *********************
do
I2C_Recv[length++]=getcI2C(); // save byte received
while(length!=20);
//******************** write sequence from slave *******************************
while(SSPSTATbits.S!=1); //wait untill STOP CONDITION
temp = ReadI2C();
//********************* Slave transmission ************************************
if(SSPSTAT & 0x04) //check if master is ready for reception
while(putsI2C(I2C_Send)); // send the data to master
ok the questions
temp = ReadI2C();
do
while(length!=20);
temp = ReadI2C();
IdleI2C();
RestartI2C();
IdleI2C();
thank you
