I'm using a microcontroller to control the length of time a solenoid is kept energized, in combination with an n-channel mosfet. I understand the importance of a clamping diode to handle the inductive voltage created when the magnetic field collapses.
However, I've also noticed that the presence of the clamping diode reduces the speed at which the solenoid opens and closes, and this has an effect on my timing and cyclic rate. Is there a certain kind of diode that is better suited for this scenario? So far I've been using schottky fast recovery diodes. If there's some way I can protect the mosfet without slowing down the solenoid, that would be even better.
Thanks in advance.
Thanks in advance.
