I was wondering that myself but can't figure out how to test that theory. I don't have any problem making solder connections in general.
It states on the station, it's for temperature controlled pencils. Opening it up, I see there's a component marked 400V-/220V MP 40/070/58 which I guess is the controller.
I've also got a butane powered iron that I tried at full heat but the result was the same.
Anyone diagnose why I can't get solder to wick? It's infuriating being able to use a solder sucker to remove the majority only to be thwarted by the remnants.
I'm using an aged Weller PU-2D station but obtaining new tips is proving difficult as it uses magnetised base tips.
I bought some new tips and plumbers flux and judging by their performance reflowing micro connector legs, the result is obvious! I've yet to try them on the wick (that job is now done) but I suspect it'll be just as effective so thank you all for your advise and support.
The question now remains, should I remove any remaining flux as I assume it's corrosive? I've got a can of contact cleaner (almost empty) but what is the active ingredient required to clean electronics, as I assume I could buy it cheaper?
My solder sucker slurps away all leaded solder. I haven't used wick for many years.
ericgibbs said:hi T,
Be careful with some of the 'contact cleaners', some types are quite aggressive on plastics.
Use lightly soaped water and an old toothbrush to remove light water soluble stains.
For more heavy flux deposits a quick wipe with with methylated spirits cloth, then a light wash with soapy water will get the job done.
Dry it off with a kitchen paper towel [or toilet paper, unused of course]
