Oznog
Active Member
Just wanted to report on this "hot tip":
I'd asked awhile back about SMD soldering for ICs. After getting some of the Zephyrtronics paste, I took advice and preheated the board in the oven to flow the flux, then used a dry, blunt soldering iron point to drag across the leads to flow the solder.
It does work, but it's hard to avoid pushing the device around, and can still leave bridges and a bit of mess if there's too much solder. It's repairable, but there's something better.
The butane Weller soldering iron (Portasol P-1k) has a catalytic hot air blower with a tiny jet, very similar to the electric ones Zephyrtronics wants $900 for. Only I bought the full set brand new with soldering tip, hot knife, air blower, and torch tips, and a case, for $20 on eBay. The results are quick, beautiful, and there's no spots the heat won't touch. Flows perfectly! Not that the soldering iron tip didn't work, but this works much much better.
