srobertjames
When I make an analog circuit using a single supply (say, 5V), I split it (using a voltage divider and a smoothing cap), to provide a reference for op amps and the like. I use that middle voltage to bias coupling capacitors.
Two questions:
1. I generally connect the 0V to the ground plane, and have the 2.5V somewhere in the middle. Would I get better performance if I put the 2.5V on the ground plane, and had a positive supply and a separate negative supply, with a smoothing cap from each one to the "ground"? Or does it make no difference, since either way I have 5V powering, and a reference half way?
2. I find that my voltage divider reference needs either small resistors and large caps, or is very noisy. Is there an IC that will do this for me, and do a better job? Is there a regulator which will give me two voltages: a full V and a half V? (I couldn't find one.) Or should I just use two voltage regulators, one delivering 5V and the other 2.5V?
Two questions:
