Morning all, i need a little bit of help here.
I have this circuit here:
What i was trying to acheive was to have the output stay at 12V for a while after the switch was been turned off. also, another goal was for there to be no load on the supply when all was switched off, as this is for use in a car.
The idea was that the switch (actually going to be the remote wire in a car, but was a switch when i was testing this, the main 12v supply would be the permanent 12v in the car) powers the coil of relay 1 which switches the supply to the coil of relay 2 and the capacitor (i want to isolate the main supply from the charged capacitor, i only want the delayed switch off on the output, not the remote lead.
relay 2 is activated and the output goes to 12v
the cap is charged up.
when the switch (remote) switches off, relay 1 cuts the supply to the coil of relay 2 but the capacitor keeps it switched on while it discharges through the coil of relay 2 (approx 1k ohm)
then once the voltage across the capacitor reaches below the drop off voltage for relay 2, it switches off, and the output goes off.
does this make sense?
i tested this, and it seems to damage relay 1, and the relay switch terminals then becomes permanently closed.
I cant understand why this is, i cant see any high currents or voltages that could damage the relay.
the relays in question are reed relays.... see here:
MEDER|SIL12-1A72-71D|SIL REED RELAY 12V | CPC
the diodes you can see in the diagram are "built in" to the relays
any ideas why relay 1 keeps getting damaged? is it the charging of the capcitor thats drawing too much current for the switch contacts of relay 1?
Thanks guys, i'm really confused by this one. i'm sorry if i havent really made myself too clear.
Thanks in advance
Thanks in advance
