I have a simple question about testing a switching power supply under load.
I have an engineer that says a power supply from a very reputable power supply vendor.
The power supply is rated for 5V 4A +/- 5%.
My engineer says he has tried hand holding a 25W resistor with 1.6 ohms resistance and also 2.5 ohms resistance to the power supply leads and also hooked up an oscilloscope to measure the voltage across the resistor.
Is this a proper way of testing a power supply? I can see that in one of the test configurations, the voltage will shoot up to over 7V, then drop to 2V, and then stabilize at 2.5V.
The manufacturer has said their power supply doesn't have a problem and that they use state of the art load testers that can test at 0% load and up to 75% load etc.
Hope I can get some help on this.
thanks,
Rix
thanks,
Rix
