Simple Coil Gun [Deleted]
Someone Electro
Someone Electro submitted a new article:
Simple Coil Gun - What is an coil gun? Its an prety fancy way of shoting projectiles out of an tube.It uses magnetic
What is an coil gun? Its an prety fancy way of shoting projectiles out of an tube.It uses magnetic force to do it.Its simply just an coil of wire around an tube that has an iron rod in it.
Heres how it works:
The rod is siting before an coil.Then a pulse is run trough the coil.The magnetic force will try to pull the rod in the midle of the coil.So that makes the rod move.Then we need to thurn off the coil right before the rod has reached the center.Its still moving so it will fly...
Read more about this article...
