simple 12v ignition coil driver needed
lev77
hi all i need help to builde a simple 12v ignition coil driver. i dont have much exp in electronics.
Any help will be good. thanks
What are you trying to do? Are you just making a high voltage spark? Does it need to be synchronized with anything?
8kw is an awful lot for an ignition coil. I think he means 8kv.
I recommend this one from RMCybernetics: https://www.rmcybernetics.com/projects/DIY_Devices/homemade_pulse_controller.htm
Frequency and duty cycle are adjusted independently of one another. The main thing you really need to be sure of is that your power source is able to produce enough current to drive the coil, which is usually >5 amps.
