Well I have to build a certain project, and so far i have been using a 9 volt battery. But I figure that a constant voltage source would be a better design. So I bought a 9 Vdc 150 mA wall transformer, yet when i checked the voltage with my voltmeter i measured 12.00 Vdc exactly. Well from doing some research online i found out that most wall transformers will give you a larger voltage at small loads. I’m not sure how much current my metronome uses, but i don't want to risk burning all those chips I used. So my questions are.
1. Should I simply measure the current of the circuit at minimum activity (least current usage.) and then use the wall transformer?
2. Should I use a 9 volts voltage regulator, to make sure i never over power my circuit.
3. If I do use a voltage regulator should i use a 1n4004 diode before the input? and should is use a .01 uFarad cap in parallel with the output voltage like I’ve seen in so many circuits on the web regarding voltage regulators?
