Hi, I have to do a small, simple project as part of my research study but has little knowledge of electronics. Wonder if anyone could help me
I need to do a simple device that can automates an occluder (plastic paddle) to test human vision. I have to control the occluder so that it rotates from 0 deg to 120 degree. Ideally it should have a switch (like a push button) to control the position/rotation. The system should be able to rotate the occluder in fast manner and less noise. Considering the plastic paddle is not heavy (weight=plastic ruler!!), I thought economy standard servo would be a good option to start off with.
I tried to put together a standard servo with a servo pot controller and it seemed to work. However, the setup uses a rotary switch and I want to be able to control it using a push button. I know I need a pair of resistor, but have no idea which one to use. Here are the components I bought!
Servo:
Specification:
Dynam model B2232.
Weighing =34g
Torque 3.2kg-cm at 4.8V @ 4.1kg-cm at 6V
Speed 0.23 sec/60 degree at 4.8V and 0.16 sec at 6V
Size 55 x 20 x 45mm.
Pot servo controller:
Specification:
Supplied complete with a 10k pot, interface, leads and a battery connector that will fit our AA battery holders. Requires a 6V supply.
Apart from the 'resistor problem', can anyone suggest what should I buy to house all the electronics parts as I need to attach it to a metal bar, vertically. I am also not sure if it is save to drill the plastic occluder and attach it to one of the servo arms and whether this will affect the servo speed.
Thanking in advance for your help.
Servo:
Specification:
Dynam model B2232.
Weighing =34g
Specification:
