servo control using port
daisordan
Hi, i connected a servo signal to RD7 in PIC18F4455. I have done the experiment for the servo movement left = 500us, right = 2ms. I use the delay to work out the pulse but it doesnt work. The servo was just stop here. Is there any problem with my code? how can i fix it?
void main (void){
TRISD=0b00000000;
PORTD=0b00000000;
PORTDbits.RD7=0;
Delay1KTCYx(5); //delay for 20ms
PORTDbits.RD7=1;
Delay100TCYx(5); //delay for 2ms
while(1)
PS:using Fosc=1MHz
while is at the beginning of a loop, not the end. You should encapsulate the stuff that loops like this
while(1)
//code that loops goes here
as is, your program sets the ports, then turns RD7 off and on once, then loops at that while(1) at the end forever.
Try connecting it an LED in series with 220 ohm resistor instead of the servo pin. Set the delays to what you think will make it blink at 1 Hz. This will tell you if the chip is running, if the port is working as an output, and if the timing is what you think it is.
