service manual
ulot said:
i double checked that and the model number is XR-C11 for the car radio/tape player
It's not listed on Sony Assist, a collection of DVD's containing all Sony technical information - although there are a number of manuals which start with those 5 characters.
Have you checked on the front of the unit?, or actually on the serial number label? - Sony often print a slightly different number on the front.
well it's got what i've said already, then SONY model no. XR-C11
FM/AM CASSETTE CAR STEREO
the rest are in japannese
want i really want to know is if there is a way to power it without the car power
well yes though i would have loved to see the service manual
it has about 6 pins for power and i need to know the volt of each or are they all a series of 12v and GND?
I thought that most radios now used a standard multiway plug?, although I've had very little to do with car radios recently. There's usually two power connections, one a permanent 12V, the other switched by the car ignition.
I'll try and check on the manuals I have at work tomorrow.
The ones listed on Assist are XR-C110, XR-C111 and XR-C113, they all seem to have 12 pin connections.
Eight are for the speaker connections, the other four are:
Ground
Permanent 12V
Switched 12V (from auxiliary on igntition switch)
12V out (to switch power amp, or electric aerial - max 300mA)
