Serial xfer of data
Mosaic
I am learning about rs232 xfer to PICs etc. So far i can achieve it via the max232 level shifter.
I'd like a procedure to read a text file in windows and transfer it serially out to the PIC.Hopefully in a manner that will permit 'looping' the file continuously. Kinda like how you can do it with a play list.
The intention is to have long scrolling messages that can be looped.
Need some help with this..
Here's a procedure in C# to send a text file continuously out the serial port:
static bool cancel = false;
        static void sendFile(string fileName, string portName, int baudRate, int lineDelay)
            using (SerialPort serialPort = new SerialPort(portName, baudRate))
                StreamReader stream = new StreamReader(new MemoryStream(File.ReadAllBytes(fileName)));
                serialPort.Open();
                while (!cancel)
                    stream.BaseStream.Seek(0, SeekOrigin.Begin);    // start from the beginning
                    while (!stream.EndOfStream)
                        string line = stream.ReadLine();
                        if (line != null)
                            serialPort.Write(line);
                            System.Threading.Thread.Sleep(lineDelay);
                serialPort.Close();
Ok, would that use RTS/CTS...? i'd need the PIC to handle flow control.
If you want to use rts/cts (hardware) flow control, specify
port.Handshake = Handshake.RequestToSend;
before you open it.
Any suggestions for a wireless serial solution...say 300 feet range?
Either use modules with built-in encoding/decoding, in which case you just feed them standard serial (RS232 style), or write your own Manchester routines, you can't generally send just plain serial over a radio link.
Check my tutorials for an example.
