chaththa19
Hi all,
Im trying to convert a HDB3 line coded electrical signal to optical signal and transmit over fiber and regenerate HDB3 electrical signal at reciever.Since HDB3 use 3 signals levels (+V,0,-V) I converted them in to 3 positive voltage levels.(1V,2V,0V).I fed it to a laser.
at reciever im using IF-D91 detector.but I couldnt obtain 3 voltage levels at reciever.Im so upset with the detector...please help me...my data rate is 3Mbps.
I used IF E96 LED as source before using laser.The variation at reciever is sooo little.below 0.2mV...is there a better detector?..do i need to use a special components with D91?
thankz
thankz
