Hi guys
This is my program for interfacing ADS7816P (a 12bit ADC) with PIC16f877 with MikroC compiler.
please help me for configuring the "Clock pulse and CS pins Timing" in program.
Is there any other faults in my program?
please tell me
Regards
These Macros define I/O Pins of PIC16f877A, connected to the ADS7816P.
#define CS RC0_bit //As an output.
#define DOUT RC1_bit //As an input.
#define DCLK RC3_bit //As an output.
This Function reads the "12 bit ADC Digitaized output data" and returns it
in a local variable, named "Sample".
long int readadc() {
unsigned char i=1,j=1;
long int sample=0;
DCLK=1;
CS=0;
for(j=1;j<=2;j++) //skip two null bits (According to ADS7816P datasheet).
DCLK=0;
delay_us(5);
DCLK=1;
for(i=1;i<=12;i++){
DCLK=0;
sample=sample<<1;
if(DOUT==1) sample=sample | 0b0000000000000001;
else sample=sample & 0b1111111111111110;
delay_us(1);
DCLK=1;
CS=1;
return sample;
The mask Function defines the 0-9 digits for common-anode seven-segments
via "switch" statement.
unsigned short mask(unsigned short num) {
switch (num) {
case 0:
return 0xC0;
case 1:
return 0xF9;
case 2:
return 0xA4;
case 3:
return 0xB0;
case 4:
return 0x99;
case 5:
return 0x92;
case 6:
return 0x82;
case 7:
return 0xF8;
case 8:
return 0x80;
case 9:
return 0x90;
} //case ended.
This is the "Main Program." (Contains the Program for multiplexing a
4 common-anode seven segments display whereas, common pins of seven segments
are connected to RB0, RB1, RB2 and RB3, and the seven segments are
driven through Port_D pins.
void main() {
unsigned short DD0, DD1, DD2, DD3;
long int val = 0;
TRISC=0x02; //Changes directions of PORTC pins; RC1 as an input,and the others are outputs.
//!----------------------(for 7-seg. display Multiplexing)--------------------
TRISB = 0xC0; //configuring Port_B 0-5 pins to be outputs and Port_B 6&7 pins to be inputs (PGC and PGD).
TRISD = 0x00; //Configuring Port_D directions to be output.
PORTD = 0xff; //Turn Off all 4, seven-segments.
CMCON=7; // Turn off comparators.
SSPSTAT.SMP=0;
SSPSTAT.CKE=0;
SSPCON=0; //Resets the SSPCON register.
SSPCON2=0;
do {
val=readadc(); //Reads the returned content of "readadc()" function (named sample).
DD0 = val%10; //Extracts Ones Digit of variable "val".
DD0 = mask(DD0);
DD1 = (val/10)%10; //Extracts Tens Digit of variable "val".
DD1 = mask(DD1);
DD2 = (val/100)%10; //Extracts Hundreds Digit of variable "val".
DD2 = mask(DD2);
DD3 = (val/1000); //Extracts Thousands Digit of variable "val".
DD3 = mask(DD3);
PORTD=DD0;
RB0_bit = 0; //Selecting Ones Digit
RB1_bit = 1;
RB2_bit = 1;
RB3_bit = 1;
delay_us(5);
PORTD=DD1;
RB0_bit = 1; //Selecting Tens Digit
RB1_bit = 0;
RB2_bit = 1;
RB3_bit = 1;
delay_us(5);
PORTD=DD2;
RB0_bit = 1; //Selecting Hundereds Digit
RB1_bit = 1;
RB2_bit = 0;
RB3_bit = 1;
delay_ms(5);
PORTD=DD3;
RB0_bit = 1; //Selecting Thousands Digit
RB1_bit = 1;
RB2_bit = 1;
RB3_bit = 0;
delay_us(5);
} while(1);
please tell me
Regards
long int sample=0;
DCLK=1;
CS=0;
DCLK=0;
delay_us(5);
DCLK=1;
for(i=1;i<=12;i++){
DCLK=0;
sample=sample<<1;
delay_us(1);
DCLK=1;
CS=1;
return sample;
switch (num) {
case 0:
return 0xC0;
case 1:
return 0xF9;
case 2:
return 0xA4;
case 3:
return 0xB0;
case 4:
return 0x99;
case 5:
return 0x92;
case 6:
return 0x82;
case 7:
return 0xF8;
case 8:
return 0x80;
case 9:
return 0x90;
} //case ended.
void main() {
long int val = 0;
SSPSTAT.SMP=0;
SSPSTAT.CKE=0;
SSPCON2=0;
do {
DD0 = mask(DD0);
DD1 = mask(DD1);
DD2 = mask(DD2);
DD3 = mask(DD3);
PORTD=DD0;
RB1_bit = 1;
RB2_bit = 1;
RB3_bit = 1;
delay_us(5);
PORTD=DD1;
RB1_bit = 0;
RB2_bit = 1;
RB3_bit = 1;
delay_us(5);
PORTD=DD2;
RB1_bit = 1;
RB2_bit = 0;
RB3_bit = 1;
delay_ms(5);
PORTD=DD3;
RB1_bit = 1;
RB2_bit = 1;
RB3_bit = 0;
delay_us(5);
} while(1);
