#include <p18f4520.h>
#include <usart.h>
#include <delays.h>
#include <portb.h>
unsigned char c;
unsigned char c1;
unsigned char c2;
unsigned char c3;
unsigned char c4;
unsigned char checksum;
unsigned char m;
unsigned char i;
unsigned char b;
void rx_handler (void);//declare the ISR function.HIGH
#define BUF_SIZE 25
* Step #1 The data is allocated into its own section.
#pragma idata bigdata
char data[8][BUF_SIZE+1] = {
{ "You Typed: 0\n\r" },
{ "You Typed: 1\n\r" },
{ "You Typed: 2\n\r" },
{ "You Typed: 3\n\r" },
{ "You Typed: 4\n\r" },
{ "You Typed: 5\n\r" },
{ "Invalid key (0-5 only)\n\r" }
#pragma idata
//location of the ISR.(HIGH)
#pragma code rx_interrupt = 0x8
void rx_int (void)
_asm goto rx_handler _endasm
#pragma code //return to default code section
#pragma interrupt rx_handler
while(!DataRdyUSART());
c = getcUSART();//start byte
c1 = getcUSART();//add
c2 = getcUSART();//cmd
c3 = getcUSART();//data
c4 = getcUSART();//chksum
checksum = (c1 + c2 + c3 + c4);
if(checksum==0xFF)
//OK
(0xFF - (c2 + 0x06 + c3)) == m;
while (BusyUSART());
//value sent
putcUSART(0xCE);
//value sent
putcUSART(c3);
//value sent
putcUSART(0x06);
//value sent
putcUSART(c2);
//value sent
putcUSART(m);
//got a valid package so send acknowledge
//and use the data
else{
//NOT OK
unsigned char m;
m = (0xFF - (c3+ 0x21 + c2));
//value sent
putcUSART(0xCE);
//value sent
putcUSART(c3);
//value sent
putcUSART(0x21);
//value sent
putcUSART(c2);
//value sent
putcUSART(m);
//Clear the interrupt flag
PIR1bits.RCIF = 0;
void main (void)
ADCON1 = 0x0F;
TRISCbits.TRISC5 = 0;
//LED
TRISB = 0;
OpenUSART (USART_TX_INT_OFF &
USART_RX_INT_ON &
USART_ASYNCH_MODE &
USART_EIGHT_BIT &
USART_CONT_RX &
USART_BRGH_HIGH, 25);
PORTBbits.RB3 = 1;
PORTCbits.RC5 = 1;
Delay10KTCYx(50);
//value sent
putcUSART(0x31);
//value sent
putcUSART(0x32);
//value sent
putcUSART(0x33);
//value sent
putcUSART(0x34);
//value sent
putcUSART(0x35);
Delay10KTCYx(50);
PORTBbits.RB3 = 0;
PORTCbits.RC5 = 0;
/* Enable interrupt priority */
RCONbits.IPEN = 1;
/* Make receive interrupt high priority */
IPR1bits.RCIP = 1;
/* Enable all high priority interrupts */
INTCONbits.GIEH = 1;
/* Loop forever */
while (1)
