Robot control with Qbasic via parallellport
_Darth_
Ok for school i have to created a program in Qbasic to control a robot via PC. Now, i don't have any idea for that program, could someone help me out?
A link, document, ... doesn't matter, only something i could us!
Grtz
Parallel port control is extremely easy in QB.
The command is OUT Address, Value.
Find out the parallel port address. Most common is 888, 956 and 658 are also common.
OUT 888, 255
255 in binary is 1 1 1 1 1 1 1 1 ... which turns on all the parallel port pins. Hoped that helped.
-Micro571[/code]
Like as already bin noted, programing in Qbasic to use the parallel port is quite simple but you have to first find the port address that your particular computer uses.
Heres a short Qbasic progam you can use to find the address of the parallel port (LPT1).
DEF SEG = 0
PRINT PEEK (1032) + 256 * PEEK (1033)
When you RUN this program it should output 888 or 956 or 632.
BTW i found it ran only when the syntax checking option was disabled, not sure why, but it works.
Qbasic stuff
Programmnig in QBasic is fairly simple.
the OUT command is the simpliest to use. The parallel port usually risides at the following addresses:
&H378 - For the data outputs of the first port LPT1 (eightlines here)
&H37A - For the control outs of the first (4 lines here I think)
&H278 - For the data outputs of the second port LPT2
&H27A - For the control outs of the second
The command:
Out &H378, 1
Will make 5V appear on Data0 on the port
Out &H378, 0
Will take all outputs to 0V on the data lines
Out &H378, 4
Will make 5V appear on Data2 on the port
Basically - write values of 0,1,2,4,8,16,32,64,128, to control the lines - you can add them up to do more than one at once. (total for 8 lines = 255)
Java smells
Qbasic stuff
The command:
Out &H378, 1
Out &H378, 0
Out &H378, 4
Java smells
I have another project similiar to his project
and the program writtin in Visual Basic Language
i want to conver it to C or java
but i don't know how to write the parallel port address
Out &H378, 4 -----> how can i write it in java or C
:roll:
PLZ HeeeelPPP Meee :!:
Go to https://www.cs.cmu.edu/~ralf/files.html
and download the entire interrupt list.
The last file (I think) contains all the ports and how to access each one.
an easy way to manipulate each bit is to use the following formula:
2 ^ n
where n is the bit number. 0 is the first bit, and 7 is the last.
So if you do:
out &H378, (2^0)+(2^1)
you have set bits 0 and 1, and the rest are cleared. Also, you are sending them to a port number equivalent to 378h.
