RF signal strength meter
rockyE70f
As a part of my final year project i am require to create signal strength meter which would work in the range of 614MHz to 806MHz. Can any body tell me what is the basic working principle of a signal strength meter or any text book or any site where i can read about, please.
Also i want to know whether there is a way to test such circuit in Proteus or Multisim or any other simulator
Thank you
If the Field Strength Meter (FSM) is only part of the project, what is the rest of the project about?
That sounds like the frequency range of UHF TV broadcast.
What sort of signal strengths are you hoping to measure.
If the field strength is high, as if you are near to the transmitter, then a simple diode detector and meter will do the trick.
However, it you are looking to measure the field strength at some distance from the transmitter,
the FSM is effectively a complete receiver with a meter measuring the AGC voltage.
Often a spectrum analyser is used, as that is effectively a calibrated receiver.
I am sure that google could turn up something.
On edit, yes it does.
Try this for a simple one:
https://www.qsl.net/n9zia/wireless/pics/fs_meter.png
Who knows?
I don't do simulators.
You can use a Spectrum Analyzer!
Edit: I thought what you wanted to use.
There's another subforum for these kind of questions:
Electronic Circuits and Projects Forum
