RF Amplifier (range upto 2.5 GHZ)
jaikanth
:roll:
Hi all,
I'm having the RF signal range upto 2.5 GHZ.
After using a splitter the incomming signal is being splitted into many outputs.Using a RF Cable,When i'm giving the signal 50 mtrs away ,
probably the signal is getting loss.
So that i 'm searching a good RF Amplifier that meets 2.5 Ghz Amplify range.
I'm not finding any Amplifier that is having Amplify range upto 2.5 Ghz.
Is any body knows then pls, send me the details regarding the amplifier.
Thank you.
Look for Mini-Circuits IC information as a place to start. Also search for amateur radio amplifiers - UHF and microwave.
You can use a single chip: MAR or ERA (4pin: in, out, GND, VSS). This amplifiers are up to 5-8GHz. How many channels do you want to amplify?
I want to amplify nearly 10 channels.
