Hi all,
I am trying to implement a reverse current/voltage battery protection circuit. My circuit uses a 3V coin cell battery to power up a MCU and I want to put a protection circuit in case someone puts the battery in the wrong direction.
I found this application note by texas instruments (https://www.ti.com/lit/an/slva139/slva139.pdf) and I followed their circuit using a PMOS FET (figure 3), using a Si2323.
When I connected up this circuit, it works fine when the battery is inserted in the right direction and I am getting 3V out from the Source of the Si2323. However, when I connect the battery in the reverse direction, I am getting a -0.6V from the source. Is this normal? Will it cause any damage to the rest of my circuits?
Thanks in advance!
Thanks in advance!
