reverse polarity circuit for pump
shankos
I am not an electronics person and need to confirm if this would work.
In the diagram pictured i am trying to make a reverse polarity circuit to a pump from a battery. operated by two switches to reverse the polarity.
on the left side of diagram the + and - are the battery. On the right the oval is a pump that is operated with reversed polarity to change its direction.
the 3 dots are switches. Single polarity double throw relay switches. By default the switch is set to one position.
In theory it should work as follows
When i change the top switch polarity goes in one direction.
When i turn the bottom switch polarity should go in the opposite direction.
There is a loop on the negative polarity that goes back to itself because the SPDT switches are defaulted to one position. There is no no contact position.
Will this cause any problems ?
And will this diagram work in practice and just not theory ?
This will work, but it's usually done with a double pole, double throw switch. It's just slicker to do it all with one click.
Best with a Double Pole/Double Throw/Center Off switch.
Ken
