haxan
After long trying with SIRC (sony protocol) and not successful, i am trying out RC5 protocol by Philips.
The following code was written for another compiler and PIC16. I want to port it for PIC18 using C18 compiler. The code written below is not working as yet. Can someone please help me with this.
#include <p18cxxx.h>
#include <delays.h>
#pragma config WDT = OFF, LVP = OFF, OSC = XT, DEBUG = OFF
#define IR_pin PORTBbits.RB0
#define TIME_MIN (5)
#define TIME_MAX (11)
#define TIME_STEP (2)
#define LED0 PORTCbits.RC0
#define LED1 PORTCbits.RC1
#define LED2 PORTCbits.RC2
#define LED3 PORTCbits.RC3
#define LED4 PORTCbits.RC4
int RC5_receive(unsigned int *, unsigned int *);
void Delay100Us(unsigned char);
void applyIR(void);
void Delay100Us(unsigned char time)
char x;
for(x=0;x<time;x++)
Delay10TCYx(9);
unsigned int IR_addr, IR_data = 0;
void applyIR(void)
switch(IR_data)
case 0: LED0 ^= 1;break;
case 1: LED1 ^= 1;break;
case 2: LED2 ^= 1;break;
case 3: LED3 ^= 1;break;
case 4: LED4 ^= 1;break;
void main(void)
ADCON1 = 0x0F;
TRISB = 0x01;
TRISA = 0x00;
PORTB = 0x00;
TRISC = TRISD = TRISE = 0x00;
PORTA = PORTC = PORTD = PORTE = 0x00;
PORTC = 0x55;
while(1)
RC5_receive(&IR_addr, &IR_data);
applyIR();
int RC5_receive(unsigned int * RC5addr, unsigned int * RC5data)
int OffTime, OnTime, DevTime, DiTime, i, j, k;
unsigned int data = 0, addr = 0;
unsigned int bit_mask;
if(!IR_pin)
for(OffTime = 0; !IR_pin && OffTime < TIME_MAX; OffTime += TIME_STEP){Delay100Us(TIME_STEP);}
if (OffTime > TIME_MAX) return -1;
if (OffTime < TIME_MIN) return -1;
for(OnTime = 0; IR_pin && OnTime < TIME_MAX; OnTime += TIME_STEP){Delay100Us(TIME_STEP);}
if (OnTime > TIME_MAX) return -1;
if (OnTime < TIME_MIN) return -1;
//* skip token
DevTime = (2 * OffTime + OnTime + OffTime / 2);
for (k = 0; k < DevTime; k += TIME_STEP){Delay100Us(TIME_STEP);}
//* get address and data
DiTime = (OffTime + OnTime);
for (i = 0; i < 5; i++)
if(IR_pin) {addr <<= 1;} else{addr <<= 1; addr |= 1;}
for (k = 0; k < DiTime; k += TIME_STEP){Delay100Us(TIME_STEP);}
for (i = 0; i < 6; i++)
if(IR_pin){data <<= 1;}else{data <<= 1; data |= 1;}
*RC5data = data;
*RC5addr = addr;
return 0;
return -1;
