Hey all, I'm new here and this is my first post, so If anything seems out of line, please bear with me
A project I am working on involves the conversion of an RC car from 6v to 9.6v.
I am pretty sure that passing the full 9.6v through the circuit board may damage something ( correct me if I am wrong of course). To eliminate that problem i am installing a Micro Potentiometer befor the board to trim the voltage down to six. I am fairly confident that it will work for that purpose.
The problem comes in stepping the voltage back up to 9.6v for the rear motor (only) that powers the car backwards and fowards. The direction of this motor is changed by switching polarities.
I'm thinking of using a relay, which would be triggered by the 6v signal coming from the board, this would open a separate 9.6v circuit to the motor. The question is, how do I go about doing that, and also, will i need two relays since the polarity has to be changed to change the direction of the motor? Any advise would be most welcome.
Thanx
Thanx
