RB port change interrupt problem
krpz
i want to enable a RB on port change interrupt, (i have a keypad connected in RB0-RP7 ports)
the project displays a message in first line of a LCD display and after the interrupt enabled from a key pressed on a keypad a new message will be displayed in the second line. my problem is that i make probably something wrong and the interrupt doesnt work.
my code (subroutines for lcd initialization and display message are tested and the messages are displayed on the screen but my problem is that when i press any key no message in the second line occurs and i think my interrupt is wrong coded) :
edit: NEW CODE POSTED BUT INTERRUPT STILL DOESNT WORK
keypad is connects to portb
i use internal pull ups
also pin1,3,5 --> column0,1,2 is connected to 5V through 10K resistors
List p=pic16f877
include "P16F877.INC"
__CONFIG _CP_OFF & _WDT_OFF &_BODEN_OFF & _PWRTE_ON & _HS_OSC & _WDT_OFF & _LVP_OFF & _CPD_OFF
ERRORLEVEL -302
#define E_line 0            ;from wiring
#define RS_line 1            ;   -//-
#define RW_line 2            ;   -//-
#define rbif 0
#define rbie 3
#define gie 7
cblock 0x20
delay_counter1
delay_counter2
temp                            ;variable store 8-bit data to send to LCD
GPR1
wtemp
pclathtemp
statustemp
endc
status equ 0x03
portd equ 0x08
porte equ 0x09
portb equ 0x06
porta equ 0x05
portc equ 0x07
intcon equ 0x0B
org 0h
goto portIni
org 04h         ;interrupt vector
goto isr
;               PORTS INITIALIZATION
;WIRING:
;     PortD                 PortE             PortB
; 0 --> lcd bus 0        0 --> lcd RS        0 --> keypad row0
; 1 --> lcd bus 1        1 --> lcd E            1 --> keypad row1
; 2 --> lcd bus 2       2 --> lcd R/W        2 --> keypad row2
; 3 --> lcd bus 3                             3 --> keypad row3
; 4 --> lcd bus 4                            4 --> not used
; 5 --> lcd bus 5                            5 --> keypad column0
; 6 --> lcd bus 6                            6 --> keypad column1
; 7 --> lcd bus 7                            7 --> keypad column2
portIni
    banksel porta
    CLRF    PORTA
    CLRF    PORTB
    CLRF     PORTE
    CLRF    PORTD
    banksel  TRISB
    movlw     b'00000111'
    movwf     TRISB
    banksel TRISD
    MOVLW   B'00000000'
    MOVWF   TRISD
    MOVWF    TRISE
    banksel OPTION_REG
    movlw     b'00001000'
    movwf     OPTION_REG
    banksel ADCON1
    MOVLW   0X06
    MOVWF     ADCON1
    MOVLW     0xCF
    MOVWF     TRISA
    BCF     STATUS,RP0          ; Bank 0
    BCF     STATUS,RP1          ; Bank 0
main
call initializeLCD
call display_initial_message
;initialise interrupt
    banksel portb
    clrf portb
    banksel intcon
    bcf intcon,rbif
    bsf intcon,rbie
    bsf intcon,gie
    banksel OPTION_REG
    bcf OPTION_REG,7    ;RBPU: 0=portb pull ups are enabled
loop goto loop
isr
    ;saving registers
    movwf wtemp
    banksel status
    swapf status,w
    clrf status
    movwf statustemp
    banksel PCLATH
    movf PCLATH,w
    movwf pclathtemp
    clrf PCLATH
    banksel intcon
    btfsc intcon,rbif
    goto routine
    goto isrend
routine
    banksel lcd_line2
    call lcd_line2
    banksel clearLCD
    call clearLCD
    banksel display_initial_message
    banksel intcon
    bcf intcon,rbif
    bsf intcon, rbie
    ;restore registers
    movf pclathtemp,w
    banksel PCLATH
    movwf PCLATH
    swapf statustemp,w
    banksel status
    movwf status
    swapf wtemp,f
    swapf wtemp,w
isrend
    retfie
initializeLCD
        call delay_20ms                ;Wait 20ms for LCD to power up
        bsf porte,E_line                   ;enable bit is high
        bcf porte,RS_line                ; RS is set for command mode
        bcf porte,RW_line             ; RW is set for write mode
        call delay_1ms
        movlw b'00111000'            ;8bit data, 2 lines, 5x8 character
        MOVWF   portd                   ; Move Working Register to PORTB
        CALL    toggle_E                    ; Enter
        CALL    delay_1ms
        movlw b'00001100'           ; Display On, Cursor Underline Off, Blink Off
        MOVWF   portd
        CALL    delay_1ms
        movwf b'00000110'            ; cursor auto increment right, shift off
        MOVWF   portd
        CALL    delay_1ms
        movwf b'00000001'            ;clear display
        MOVWF   portd
        CALL    delay_1ms
        BSF     porte, RS_line           ; LCD in Character mode
        return
clearLCD
        BCF     porte, RS_line             ; LCD in Command mode
        MOVLW   B'00000001'         ; Command: Clear Display
        CALL    delay_1ms
        RETURN
toggle_E
        bcf porte,E_line         ;data is enter on the falling edge
        call delay_1ms
        bsf porte,E_line         ;E_line ready for the next data string
return
lcd_line2
        bcf porte,RS_line
        movlw b'11000000'
        movwf portd
        call toggle_E
        call delay_1ms
        bsf porte, RS_line
        return
;lcd display initial message
        movlw d'0'                        ;table line to start printing from
        movwf GPR1
        call display_message
        return
;routine for displaying characters on the lcd
display_message
        movf GPR1,w
        call message_table
        movwf portd
        xorlw b'00000000'
        btfsc status,2
        goto $+5
        call toggle_E
        call delay_1ms
        incf GPR1
        goto display_message
        return
message_table
        addwf PCL,f
        retlw    A'h'    ;0
        retlw   A'e'    ;1
        retlw    A'l'    ;3
        retlw    A'l'    ;4
        retlw    A'o'    ;5
        retlw    A' '    ;6
        retlw    A'w'    ;7
        retlw    A'o'    ;8
        retlw    A'r'    ;9
        retlw    A'l'    ;10
        retlw    A'd'    ;11
        retlw    H'0'    ;12
;   Delay Routines
;4MHz clock frequency
delay_1ms
        movlw 0xc6
        movwf delay_counter1
        movlw 0x01
        movwf delay_counter2
delay_1ms_0
        decfsz delay_counter1, f
        goto $+2
        decfsz delay_counter2, f
        goto delay_1ms_0
        goto $+1
        nop
        return
delay_20ms
        movlw 0x9e
        movlw 0x10
delay_20ms_0
        decfsz delay_counter1,f
        goto $+2
        decfsz delay_counter2,f
        goto delay_20ms_0
        goto $+1
        nop
        return
stop
    goto stop
end
3.4.3 INTERRUPT-ON-CHANGE
All of the PORTB pins are individually configurable as an
interrupt-on-change pin. Control bits IOCB<7:0> enable
or disable the interrupt function for each pin. Refer to
Register 3-8. The interrupt-on-change feature is
disabled on a Power-on Reset.
Yes , but i think i dont have Power-on-Reset enabled, in my configuration bits i have _PWRTE_ON (Power-up Timer), correct me if i am wrong
banksel portb
clrf portb
I only know assembly, but shouldn't all these be in capitol letters? if not, you're won't get the correct banks?
Hello krpz.....
Quite a few things to note..
A) there is no need to define all the registers and register bits as you include the "p16f877.inc" which has them all in (and as Joe kindly explained they are in uppercase)..
B) You cannot initialise your LCD like this.. I have made a change there!!
C) You cannot clear the RBIF flag manually... You have to read PORTB!!
D) You had the OSC set for HS.... With a 4mhz you must set it to XT.
E) you have specified the wiring as RS = 0, E = 1 and RW = 2 but set it as E = 0, RS = 1 and RW = 2.
F) the E line should be low for Idle..
List p=pic16f877
__CONFIG _CP_OFF & _WDT_OFF &_BODEN_OFF & _PWRTE_ON & _XT_OSC & _WDT_OFF & _LVP_OFF & _CPD_OFF
ERRORLEVEL -302
cblock 0x20
delay_counter1
delay_counter2
GPR1
wtemp
pclathtemp
STATUStemp
endc
org 0h
goto portIni
goto isr
;WIRING:
;     PORTD                 PORTE             PORTB
portIni
    banksel PORTA
    CLRF    PORTA
    CLRF    PORTB
    CLRF    PORTE
    CLRF    PORTD
    banksel  TRISB
    movlw     b'11110000'
    movwf     TRISB
    banksel TRISD
    MOVLW   B'00000000'
    MOVWF   TRISD
    MOVWF    TRISE
    banksel OPTION_REG
    movlw     b'11000000'
    movwf     OPTION_REG
    banksel ADCON1
    MOVLW   0X06
    MOVWF     ADCON1
    MOVLW     0xCF
    MOVWF     TRISA
main
call initializeLCD
    banksel PORTB
    clrf PORTB
    bcf INTCON,RBIF
    bsf INTCON,RBIE
    bsf INTCON,GIE
    banksel OPTION_REG
    bcf OPTION_REG,7    ;RBPU: 0=PORTB pull ups are enabled
loop goto loop
isr
    ;saving registers
    movwf wtemp
    banksel STATUS
    swapf STATUS,w
    clrf STATUS
    movwf STATUStemp
    banksel PCLATH
    movf PCLATH,w
    movwf pclathtemp
    clrf PCLATH
    btfsc INTCON,RBIF
    goto routine
    goto isrend
routine
    call lcd_line2
    call clearLCD
    ;restore registers
    movf  PORTB,w
    movf pclathtemp,w
    banksel PCLATH
    movwf PCLATH
    swapf STATUStemp,w
    banksel STATUS
    movwf STATUS
    swapf wtemp,f
    swapf wtemp,w
isrend
    clrf INTCON		; for some reason the TMR0IE is bieng set
    bsf  INTCON,RBIE 	; so I disabled it here
    retfie
initializeLCD
	bcf PORTE,E_line                   ;enable bit is high
        bcf PORTE,RS_line                ; RS is set for command mode
        bcf PORTE,RW_line             ; RW is set for write mode
	movlw b'00110011'
	MOVWF   PORTD
	CALL    toggle_E
	call delay_20ms
	CALL    toggle_E
    	call delay_20ms
        MOVWF   PORTD                   ; Move Working Register to PORTB
        CALL    delay_1ms
        MOVWF   PORTD
        CALL    delay_1ms
        MOVWF   PORTD
        CALL    delay_1ms
        MOVWF   PORTD
        CALL    delay_1ms
        BSF     PORTE, RS_line           ; LCD in Character mode
        return
clearLCD
        BCF     PORTE, RS_line             ; LCD in Command mode
        CALL    delay_1ms
        RETURN
toggle_E
        bsf PORTE,E_line         ;data is enter on the falling edge
        call delay_1ms
        bcf PORTE,E_line         ;E_line ready for the next data string
return
lcd_line2
        bcf PORTE,RS_line
        movlw b'11000000'
        movwf PORTD
        call toggle_E
        call delay_1ms
        bsf PORTE, RS_line
        return
        movwf GPR1
        return
display_message
        movf GPR1,w
        call message_table
        movwf PORTD
        xorlw b'00000000'
        btfsc STATUS,2
        goto $+5
        call toggle_E
        call delay_1ms
        incf GPR1
        return
message_table
        addwf PCL,f
        retlw    A'h'    ;0
        retlw    A'e'    ;1
        retlw    A'l'    ;3
        retlw    A'l'    ;4
        retlw    A'o'    ;5
        retlw    A' '    ;6
        retlw    A'w'    ;7
        retlw    A'o'    ;8
        retlw    A'r'    ;9
        retlw    A'l'    ;10
        retlw    A'd'    ;11
        retlw    H'0'    ;12
;   Delay Routines
delay_1ms
        movlw 0xc6
        movlw 0x01
delay_1ms_0
        goto $+2
        goto delay_1ms_0
        goto $+1
        nop
        return
delay_20ms
        movlw 0x9e
        movlw 0x10
delay_20ms_0
        goto $+2
        goto delay_20ms_0
        goto $+1
        nop
        return
stop
    goto stop
end
One last thing... You don't need to banksel INTCON as it resides in all the banks..
It works!! thank you very very much!
Now i can enter into the world of interrupts :)
Two more questions if you can explain:
1. in your code at first you put:
   banksel OPTION_REG
    movlw     b'11000000'
    movwf     OPTION_REG
that disable pull-ups
and then when interrupt is initialized:
    banksel PORTB
    clrf PORTB
    bcf INTCON,RBIF
    bsf INTCON,RBIE
    bsf INTCON,GIE
    banksel OPTION_REG
you make this on purpuse? in order the interrupt become functionable?
2. in LCD initialization what this part of code do:
initializeLCD
	movlw b'00110011'
	MOVWF   PORTD
i cant find in the lcd datasheet
thanks in advance! you make my day!
Sorry the first was me messing with RBPU's control... And to see what intedge would do.... you can delete that line..
All Hitachi compatible LCD's must be initialized with 0x33 twice ( for 8 bit interface ) and 0x20 twice ( for 4 bit interface )...
My initialize routines contain..
wait 15mS
0x33
wait 5mS
0x33
wait 5mS
// the busy can now be checked..
Then function 0x38
Then Display , cursor, 0x0D
Then direction ,font, 0x06
Then clear, set home 0x01
Always works for me.
I've included my LCD pdf..
useful things to know about lcd display initialization.
in your above code i try to put another interrupt, in the first time i like to display a message1 for example and after this if you press another time a key lcd will display message2.
i think to add a variable (intcounter). first i give intcounter value 0x01 (in main before interrupt intialization), then inside isr after saving registers i put this code:
btfsc intcounter,0
goto int1
goto int2
int1
   btfsc INTCON,RBIF
   goto routine
   goto isrend
int2
   btfsc INTCON,RBIF
   goto routine2
   goto isrend
routine 2 will be the same with another message
i try to simulate but i take strange results, sometimes i am inside message1 subroutine and after a step out the programm send me inside inililizeLCD subroutine!!!
i think i have 2 things that i made mistake,
1. i need to put this code:
bansel PORTB
clrf PORTB
after isrend maybe???? or somewhere else???
2. my first routine contains this lines of code to change intcounter value
routine
   movf intcounter , w
   xorlw 0x01
   movwf intcounter
after this intcounter will have value= 0x00 , so in the second interrupt routine2 will be executed
but when i simulate after first interrupt intcounter have 0x01 value again....
Think twice about doing too much inside of an interrupt... The pic16f877 has only 8 stack positions.. The interrupt uses two positions.. The call to LCD routines requires 1, then nested are two calls to delay routines...
I tend to keep the interrupts as short as possible... I run everything in the super loop and flag the routines from the interrupt...
Your super loop is at the bottom of your interrupt init
 Loop  goto loop
If you expand:-
Loop
   btfsc IntFlags.1
   Call LCDRoutine1
   btfsc IntFlags.2
   Call LCDRoutine2
   ; etc...
   goto Loop
That means the code will only be executed IF the interrupt has been fired.. This will keep your interrupt nice and short.
