RA0 input, 16F690
ibwev
I am trying to recreate the following scenario.
Setup is the following:
RA1-Motion Sensor (I am using a button), RA0 Activate System button, RA5 Buzzer RB5-Red alarm set, RB4-Green system off
The following is what program should do:
Green light blinks 1/10 of a second while system unarmed (RA1 has not been pressed)
Once RA1 is pressed, green light stops blinking and red light starts blinking at 1/10 second intervals
If RA1 is pressed (motion sensor), alarm sounds on RA5
My problem follows:
1) When ANSEL <1,0> is set and TRISA <1,0> is set, the MPLab Simulator can not set RA0 high.
2) When ANSEL <1,0> is cleared and TRISA <1,0> is set, the MPLab Simulator will set RA0 high.
When PIC16F690 is programmed using example number 2 from above, RA0 does not appear to accept a 5 volt input. It does not switch the blinking green light to a blinking red light.
What am I doing wrong?
  • Alarm.asm
Your code has some bugs I wouldn't use the timer for bounce
Have a look at this
Init
		bcf		STATUS,RP1
	bsf 	STATUS,RP0	;Bank 1 for OSCCON and Option+reg
	movlw	b'01110110'	;2MHz internal oscillator
	movwf	OSCCON
	movlw	b'1111'		;wdt max prescale
	movwf	OPTION_REG	;wftcon pg 190
	banksel TRISA       ; set's to right bank
	clrf 	TRISA 		;clears the bank
	banksel TRISB
	clrf 	TRISB
	banksel ANSEL
	clrf	ANSEL		;set's digtal I/O
	banksel	ANSELH		; there two for this chip
	clrf	ANSELH		; this set'e the AN9 to 11 digtal I/O
	clrf	ADCON0
	banksel TRISA
	movlw 	b'00000011'  ; this set's your pins as input and output
	movwf	TRISA
	banksel TRISB
	movlw	b'00000000' ; set's all output
	movwf 	TRISB
	banksel PORTB
	clrf 	PORTB
That set's you up right
I would use a delay for debouncing
You need to redo this part I't not really doing what you want it to do
start
ButtonTest
	btfss	PORTA,RA0	;has alarm button been pressed
	goto	AlarmButton
	goto	ButtonLoop
AlarmButton
	bsf		PORTB,4	;turn on unactive light
	call	ButtonBounce	;keep light on for tenth of a second
	clrf	PORTB	;turn light off until wtd resets
greenoff
	btfss	PORTA,0	;test ra0 keep light off
	goto	greenoff
	goto	ButtonLoop
ButtonLoop
	call	ButtonBounce	;make button safe to test
	goto	ButtonLoop
	bsf		PORTB,5	;has to be "RB#"
						;turn on red light to show button has been pressed
	call	ButtonBounce	;alarm light on for tenth of a second
lightsoff
	clrf	PORTB	;turn off lights for remaining cycle
	btfss	PORTA,1	;has motion sensor been activated,
	goto	lightsoff
	call	ButtonBounce	;has sensor been active long enough
	goto	lightsoff
Alarm
	clrf	WDTCON		;Sound alarm indefinitly
	bsf		PORTA,5	;sound alarm
	goto	Alarm
ButtonBounce
